atedepumpo
I’ve reviewed lots of good information on this site and others, but any additional tips are greatly appreciated.
My first question is the easy one. Does anyone have photos of factory welds for the Torque Shaft frame bracket. I’m definitely an amateur welder, but hope to make it look as “factory” as possible.
Regarding the 4-speed hump, my main concern is with the positioning of the front bracket for the console. In my picture, you can see grind marks on my used hump showing that the bracket was at least partially welded to the hump. Does anyone have a picture of the relationship of the console front bracket to the hump? I’m wondering if the bracket is still partially welded on the existing tunnel, or is the bracket totally on the hump when everything is positioned correctly. Maybe I’m overthinking this, but I don’t want to lose the positioning of the bracket. I’m wondering if I can maybe just cut the welds on the left side of the bracket (while leaving some of the factory weld on the right side of the bracket), and then slide the hump under the bracket so I don’t lose the position of the bracket?
Is there a known dimension between the front of the hump and the seam for the front of the floor pan? I guess I will mockup the transmission and shifter before final positioning of the hump. Did the factory use periodic tack welds, or maybe plug welds? Any other tips? Thanks.
