[Found!] Washer reservoir for early A
They are reproduced. Check out what you have. I bought a 66 for my 66 Barracuda, only to find it originally came with a 65 washer bottle.
I see the repop stuff, I am still unsure which I need. There seems to be 2 types, one with a pump connection in the back, and then another with a pump outlet on the side. The 2497502 which I suspect is what I need, comes up on some sites as being for Manual Pump, which I do not have. I have a small little (3 screw mounted) pump in the engine bay on the battery side. Not sure if my pump works. I think I take a small tube, connect it from the outlet on the tank, to the pump, then from the pump to the squirters. ? I guess the switch for this must be depressing the windshield wiper knob?
... I have a small little (3 screw mounted) pump in the engine bay on the battery side. Not sure if my pump works. I think I take a small tube, connect it from the outlet on the tank, to the pump, then from the pump to the squirters. ? I guess the switch for this must be depressing the windshield wiper knob?
That all sounds right. Look at what you have, assuming yours is just busted, and go by looks.
I have a nice used correct 66 dated pump that tests working. If your interested send me a message
I just tried pushing the wiper button, and I hear the pump do a single click, and nothing else. Should I hear whirring or something? I wonder is it possible to repair the pump? maybe jammed? or rusted? Are those things take=a=partable?
