mean318
Well this is what I have, a High flow Mopar Performance water pump and every since I put it on I have had a small water leak. At first it looked like it was the hose so I would continuously tighten the clamp on it, then when I had it on the lift the other day I realized that it was coming from right where the outlet is but on the pump to timing cover area. I then saw that a bolt from the timing cover was actually contacting the outlet right above the hose. I have repeatedly tightened the water pump housing bolts to no avail. I am thinking that the bolt is not letting the pump get tight enough on the sealing surface. Has anybody had this problem before? BTW I have all the bolt threads sealed with sealant just to let you know.
