[WANTED] Water pump pulley
I have 2 of the 3 pictured
Thanks but the depth if the pulley is more than 2 5/8". Your ruler has a little extra on the end before the first line of measurement. I usually measure the pulleys with a tape measure down through the center hole to the table.
See if these will work, I can send better pics later today. Early cast pump on the left. Last pic is alum pump pulley.
Regarding photos above - the pulley on the right is 1970 & up 340, 318 pulley. I have one also in CT
I got the 2 5/8'' pulley , but its 6 15/16 diameter...
That's what I have now. The 6 15/16" dia. puts it too close to the crank pulley rear groove so much so that I can't put the belt on it without removing the fan and pulley first. Mine is also 2 11/16" deep and doesn't line up with the rear groove of the crank pulley unless I put a spacer behind it.
mine is 2 5/8'' inch deep ...
I ran it with a stock hemi lower pulley for a couple yrs.
