waterpump bypass hose
Eric Mulay
san luis obispo california
I have a Edelbrock 7577 intake on the 360 magnum and the LA style water pump, i have purchased 2 bypass hoses, both wont fit, they do not have the correct curve, ...
what has worked for you guys?
thanks
I've used this from dealership on a LA 273. Silicone lined.
That intake fitting comes off at a 90* angle unlike the LA style intakes that are more like a 45. You might have to trim the hose down a bit and muscle it on but it’ll go on ok.
As mentioned by 67dartgtgo, trim. Or as we use to say "if it don't fit, make it fit":)
View attachment 1715534250 That intake fitting comes off at a 90* angle unlike the LA style intakes that are more like a 45. You might have to trim the hose down a bit and muscle it on but it’ll go on ok.
I got it in.. But it had a good kink in it ..
Then i trimmed it.. Then i trimmed it again..
Then it was too short.
I see yours.. So.. Ill get another one. Try again.
Two of these (One for Intake Manifold, on for water pump):
Mopar Perf. Intake Manifold Bypass Fitting Adapter #MOPP4876374
One of these:
Mancini Racing Intake Manifold Bypass Hose Kit #MRE4876373
Both from Mancini
