Weiand low deck tunnel ram top?
J.V
Active Member
Finland
Hey!
I have Weiand low deck tunnel ram part number 1986 with single quad top and I am looking for dual quad top. Does any one know will Weiand part number 1913(same as rb tunnel ram has) top fit for this intake? I guess this is older casting because this has 2 part plenum with 6 bolts for top part of plenum?
Do you have a picture, can't seem to find one on the net for that #
This is only picture I got right now.
I don't think I have ever seen that top before,
but I think the 440 top will bolt onto the base.
Yeah that makes sense but this one has 6 bolts in top and usually i have seen these with 4 bolts? Does anyone know for sure if that rb top fits or have dimensions of rb version top bolt pattern?
Yeah, plenum is attached with 4 bolts. I meant that top of plenum is 6 bolts. I need info will that rb model top(including plenum) fit to low deck base?
Thank you! I measured and it was 9 9/16 (9,566) x 4 inches exactly. so I'm pretty sure that rb version top will fit.
