Welding body panels ???
SleeperScamp
Texas
When welding two body panels together with a butt weld do you put a piece of metal behind the panels as a " backer" ???? Thanks
Can't hurt as long as alignment is maintained.
Also will help with blow through.
If you use a copper paddle, the weld wont stick to it, but the paddle can help you apply pressure or what ever you might need to make the weld better.
