For one,it makes the sandpaper last longer,wich save money.Wet sanding doesnt make dust that can get trapped in hidden places only to come out when you paint the car.Any time you wet sand,USE A SANDING BLOCK!It doesnt have to be an expensive block,i use regular paint paddles,or mixing sticks,what ever you want to call them.Cut them about 6 inches long,roll the sandpaper tight around them and go to it.Use a guide coat.Either a spray primer,or an actual guide coat you can buy.Its just misted on lightly.Yous sand in a criss cross pattern,just until the guide coat goes away,then move on.When you water sand before buffing,or color sand as a lot of folks call it,its the same principle,just finer sand paper
