MOPARHOTRODS
what deep oil pan if any can you use in a 68 a body with 383
I ran a 8 qrt morose oil pan on the 440 in my 73 dart with the stock King frame and steering linkage.running a direct connection K frame what oil pan can you use that won't interfere with the steering
Just unwrapped (still on the engine) and quick looked at the "old" pan out of curiosity from your comment. It's not a Milodon. It's in fact a modified 971 with a part number 9718804 (I believe). It does in fact have a small cone shaped clearance on the passenger side, third flange bolt from the rear............Is there a dimple for the idler arm on the pass side........if so yes...........kim.......
moparwillybb just listed the Milodon pan for sale hereI ran a Milodon pan on my 440 with the DC K member. 71 Dart, the pan kicked out to the sides so its not quite as deep as a regular deep pan. No issues with stock steering.
That pan isn't notched out at all for the steering linkage. The notch I have on my 699 pan (which is identical to the 187 pan) needed to be slightly banged out to fit nicely. I can't see that there would be no interference with this one.The best 7 quart B/RB pan is the Milodon #31580.
No ground clearance or stock steering issues.
Trap doors give complete oil control.
