I would have them remove the bearing and chamfer the hole.
like krazykuda said this would probally work but if I was doing a 5 to 8000 dollar build on a nice engine I want everything as close to perfect as I could get itis the back of that bearing sticking out past the casting? You would have to look at it from the other side to tell.
The side pictured looks like the edge of the bearing is at the edge of the casting. How does it line up on the other side? Is the bearing centered in the casting? Could the oil hole be slightly off locaton/not centered in the casting?
How do they chamfer the hole from the cam bearing side? It is drilled from the main bearing side, the casting is in the way to machine from the other side. How do you get a cutter in the cam bore to chamfer the hole?
With a Dremel. By hand. Old school.
Obviously you'd have to remove the cam bearing to do it. This, of course, only applies if the problem lies with the hole bored in the block, and not the bearing.
I'm leery of using a bearing that has been hammered back into position. I don't think there would be room to get a bearing installation tool to get the job done. IMO, replace the bearing and hope for better luck installing it.
They should be doing that, IMO.They are a little past the casting. I can try to whack them to center the bearing. :violent1:
