keith9291
I just recently bought a 71 Swinger with 75,000 original miles on it. Car is in fantastic condition and runs great...A/C still blows cold. I am wondering what grade gas I should be buying and should I be adding any lead additives? I dont want to be using the wrong fuel and do any damage. I found this "fuel usage statement" in the paper work i got.
Chrylser supports all efforts to control and reduce vehicle emissions and will continue to design its engines towards this end. As a result, our 1971 "regular" fuel engines are designed to operate in normal usage on 91 octane "low lead" or "low polluntant" gasolines containing at least 0.5 grams per gallon of lead, or the equivalent additive.
such fuels are suitable for use in all 1971 Chrysler Corporation passenger cars, except those cars equipped with engine designed specifically to operate on premium fuels.
These engines are,
340 Cubic Inch Displacement
426 Cubic Inch Displacement Hemi
440 Cubic Inch Displacement High performance
(with single 4 barrel carburetor, 9.7:1 compression ratio, 370 H.P.)
440 Cubic Inch Displacement with 3-2 barrel carburetors.
Chrysler Corporation recommends against continuous use of completely lead-free or clear gasolines which do not contain suitable lubricating additives such as lead or phosphorus. Continuous use of such fuels in normal driving could cause valve seat burning, resulting in excessive emissions, poor performance and possible engine failure.
These engines are,
