Nov 22, 2023 #1 rbkt65 FABO Gold Member FABO Gold Member Joined Dec 25, 2017 Messages 2,841 Reaction score 2,292 Location jerseyville, illinois. That is used in the light sockets that illuminate aftermarket gauges. It seems smaller than 22 gauge. Is it readily available anywhere? TIA.
Nov 22, 2023 #2 Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 19,159 Reaction score 16,538 Location Northern Colorado If you have a section you can count the number of strands and then with a caliper measure the diameter of the strand. There are charts online that will give you the gauge. It's easier if you measure in mm
Nov 22, 2023 #3 67Dart273 FABO Gold Member FABO Gold Member Joined Oct 14, 2010 Messages 62,697 Reaction score 37,130 Location Idaho Regardless of the size in the pigtails/ sockets, I would not use anything smaller than 18, simply for physical strength
