well it is time to change the speedo gear in the tranny. I was cruising down the road the other day and the speedo was sitting on 90. I forgot to change it when I done the rearend and everything else. I think I need a 32 or 33. what do you think. Just want to make sure. I found a chart but didnt make sense. I am running 3:23 gears in a Duster. 440/727. tire size on rear is 245/60/15. The chart I found said my tire diameter was 26.6. that put me in the midle of a 32 and 33 tooth gear. which one is right for me. also would it be a short shaft style or a long shaft style I need. Thanks,Bill
