What Idler Arm is this?!
In your pictures on the first post, if the idler arm has 7324 on it and that's the one your looking for I have one new in the box if your interested. MOOG part number on the box is K7086 for 73-76 A body. I bought it to replace mine but didn't use it.
where are you located? and how much are you asking?
How' $35 shipped in a flat rate box? If I could find the receipt I'd take it back, I think I paid around $52 for it. Here's some pictures. PM me if you want.
Are you guys still around? I have the same problem fredsmedina had 7 years ago. My '67 Barracuda pitman arm has the identical "7324-C" marking on it; my steering assembly has also been replaced and I have not figured out what it came from. Tried Moog K7066 for '73+ Charger, it is so close but not quite. Charger is not an A-body I think, that's probably where I went wrong. Wondering if the Moog K7086 that dusterman70 had, worked for fredsmedina. In the picture the bottom idler is my "7324-C" that I'm trying to replace. The top idler is Moog K7066, it's close but not quite right. My idler is about 5 1/4" center-to-center on the bolts, and about 1 1/4" drop from bottom of K-member bracket to bottom of center link end of the arm.
To close the loop on this, the correct idler arm was Moog K7086 for '73+ Dart, etc. It has "7324-C" cast into the part itself, both the old part and the replacement part. This is the bottom idler arm in the picture I posted earlier.
