Ok, this is a new one. I bought a new car about a month ago, and it's the first car with remote start. First time I used it I didn't know I needed the key to be in the ignition and turned to on position; it has to be like that in order to place the shifter into drive or any other spot. Now, the What IF is this. What if you were out at the bar drinking and you knew you had to much to drink. You remote start the car and then sit in it to go to sleep. Can the cops give you a DUI or OVWI with the car running and no key in the ignition?
