Juhosaphat
Member
So when I brought my 72' Duster home, it came with a whole crap load of parts. Two milk crates full of smaller stuff. For the most part, it was junk old take off stuff. But some of it might be of value to somebody as I don't know what some of it is and more than likely won't have a use for it anyway.
If anybody has any information on what's in the pics in regards to what it is or what it's worth, please share as this is my first Mopar and I have no clue what any of this stuff would go for.
(The suspension stuff I know what it is, but not what it'd be worth to somebody)
The cable I have no idea about. It may not even be from the Duster. The vents I'm certain are dash inserts which I'd have no use for as it's going to have a sheet metal dash and no heat since it's a race car. The other brackets I've got no clue on either.
The wire looks like maybe a radio antenna cable? No idea what the plastic things are. Thought they were like a seat belt buckle or something but without an interior, I can't really compare it to anything.
Factory strut rods with new rubber bushings, been blasted. Looks like maybe a trunk latch? No idea what the plastic pieces are.
Factory upper and lower control arms with all new bushings pressed in, all have been blasted and are ready for paint. They will be available once I get the aftermarket k-member ordered.
Factory k-member that has been 'modified' to fit the Mustang II manual rack. It is not a close ratio rack but it is brand new. It would go with the k-member if anybody was interested in it and will only be available once I get the aftermarket k-member ordered.
