What is the item I tried to circle? It actually is for my 2004 Jeep wrangler.
jbcalhoun
Active Member
Midland, TX
It is the a/c manifold that bolts to the compressor. I need to know if it is removable and maybe where I have a freon leak.
It looks like the pressure relief valve. In case pressure goes way to high, this would physically burst to relieve pressure to prevent damage to other components. Not sure if it's replaceable on Jeep, but it is on some compressors. Picture looks like it screws in, which would suggest replaceable.
Check the low and high pressure valves. Those Schrader valves can go bad. otherwise you can rent the stuff from oriellys and put some UV dye in the system. I just did this and found out my evap core was shot.
