What is the "trick" on 727/ 518 (46RE) dust shields??? rubbing/ noise
67Dart273
Idaho
Got the White Whale III fired up on the hoist, checking levels, adding fluid, oil, etc, and "the dreaded rubbing sound." This MIGHT be the same dust shield I tried to install on the White Whale I (which lives without one) and had it off two or three times before I left it off. What are the popular tricks to bend, flatten, trim, ?? to fix these?
Hell I don't even know WHERE it's rubbing!!!
Found it. Removed the cover, and there's a tiny rub mark up next to the crank where the small "half moon" is cut out in the dust cover. I'll trim/ grind a bit off and reinstall
