What is this clip called for headliner trim molding…
Wvbuzzmaster
West Virginia
I broke a tab off this clip that slides into the metal headliner trim molding and snaps to the pinch weld above the door glass. There are 4 clips total and mine were all good until I broke one trying to straighten it today… it’s spring steel so I’m not trying that again but I also can not find them online to buy a replacement, new or used.
Headliner door trim clip? I had very similar ones to this on a 70 Road Runner. It holds the trim piece above the door on the interior, correct? I think they were pretty much the same on all older Mopars that metal trim moldings above the door. I'm sure someone here has what you need. You said there were 4 clips. Is that per side or both sides? If you have 3 clips left on 1 side, that would be plenty enough to hold that trim piece, IMO.
