what is this peice of the kickdown.
63VALIANT*KISS
Eureka,Ca Humboldt
this peice right here the rod. i think it connects to the carb.
That's the kickdown/transmission pressure rod and throttle cable hold down. It mounts to the manifold.
The slotted rod does connect to the carb and there should also be a spring that hold the rod forward. If you're using a Holley, there's an additional piece that can be purchased to adapt it and it mounts to the throttle itself.
Never run a 727 without it (with the exception of some modified transmisions).
The piece on the left , the longer one goes down the firewall to the tranny linkage and it connects to the slotted piece up near the carb as posted earlier by someone else .
yes its just i recently bought a uncomplete linkage . and the guy at the shop pointed it out me. was figureing out what peice was missing thanks
