What Kind of Motor Mount is This?
68Darthawaii
Waianae, Hawaii
I have a 68 Barracuda with 360 in it. It has a 67-72 K frame in it and need to change motor mounts. I never seen this kind of mount/bracket before? Has anyone seen this before? The pic is the driver side mount. Thanks!
looks to be some early version of a poly lock... and smallblock mount should work it just wont have the "lock" unless you get a poly lock setup...
that's one of the best insulators you can have. when the motor torques over the 2 pieces of steel touch and stops the stretching of the rubber so it doesn't break. you should keep it.
