YoMopar
New Member
Hi - I have a 23 spline A833 trans and I need some help finding out what body style it fits. Here is the info:
These are the casting number on the tail shaft:
AL
C13212-1
X5 (plus either an "A" or a "4" in a circle following the X5)
The casting numbers on the main case housing are PP8335240, C13303 VX, and G138785.
The distance from the front of the tailshaft to the center of the mounting pad on the tailshaft is approximately 4-3/4". The mounting pad I am referring to here is the one which connects the transmission to the crossmember that bolts to the frame of the car.
Also, the overall length of the tailshaft is approximately 12-1/2" and the distance from the rear of the tailshaft to the center of the first bolt hole for the shifter is 3". The distance from the rear of the tailshaft to the center of the second bolt hole for the shifter is 5". Last, the distance from the rear of the tailshaft housing the center of the hole on the bottom
for the shifter is 3-5/8". The 3" and 5" distances are for the two top holes for the shifter mounting and the 3-5/8" dimension is for the bottom of the three.
There is only ONE set of bolt holes for a shifter on the tailshaft.
If you can be of any help with identifying the application of this A833 trans, please let me know.
Thanks!
Ted
AL
C13212-1
Thanks!
Ted
