scamp340
Active Member
I just bought a Comp Cams roller rocker set 1322-16 from my 1970 "340" with a Mopar Performance "Purple Shaft" cam. I am replacing my old "273" adjustable rocker set up. The old set up used the Crane Cams ball and cup style pushrod. I now need a ball and ball style set up. I have four lengths to chose from in the Comp Cams catalog. The lengths are 7.450", 7.500" (stock length, according to Summit), 7.513 which the Comp Cams catalog says is for non adjustable rockers, and 7.550". I've read that the stock length for a 1970 "340" is 7.534". As well I plan on using lash caps from Comp Cams.
