What size fuel line???help.......
MR JIM
Active Member
High desert ca
Hi there guys.
Running 451,fuel cell,140gph electric fuel pump,dual 450cfm Holley's and tunnel ram....What size fuel line should I run???
If An-6 is the same size as 1/2" then use it...we ran a 1/2" aluminum line from Holley big blue pump to gas log for a 440 six pack set up and then ran a 1/4" return line back to the sump...it was very noisy before we ran the return line
