dennday67
So here's the combo so far. 71 360 .030, 10.5:1 kb 107 pistons, stock crank, stock rods, MP purple shaft .484 lift cam, weiand 8007 dual plane intake, 600 cfm vac secondary carb, stock J heads, stock size rockers (new rockers and shafts), 727 trans with street strip shift kit, b body 8.75 489 pig with limited slip (gears undecided but in the range of 3.55-3.91). Building the car for the street not the strip. Been getting mixed suggestions between 2200-3000 stall. Any suggestions would be greatly appreciated.
