I think your right. I have been told to change plugs, leads, etc but I don't think they would make this issue. I need to buy another dizzy and leads for my other engine soon. I will swap the dizzy out for a test and see how it goes. I can run it without the msd box for a trial run.I don think spark plugs have much to do with timing "jumping" around. I doubt valve spring pressure will affect timing either. Stock plugs are nothing more than a starting point if you are running anything other than FI or carb. Blowers, turbos etc all require different tuning, plug gap, heat range, etc etc etc. I would think bad damper or msd box but I am no blower/turbo expert.
