What transmission ??
Gjason89
Mcallen
So I don't know how to REALY explain this but I buaght a 1984 360 with a transmission that both came of a van? It's for my 1969 dart but I'm wondering how can I even have an idea of what transmission it is and if it'll fit in my car??
It's probably a 727. Look at the pan. If it has a "kick out" at the passenger side front corner, that's what it is.
I bet Rob's right. I think the 727 is all they used in 84 Van's with a 360. Here's a picture of a 727 pan. If this is what it looks like it's a 727. Was the van a 1/2 ton, 3/4, or 1 ton? If it was a 1/2 or 3/4 ton it should work fine for you. If it was a 1 ton it might work or might not cause some 1 ton van's and trucks used a bolt on driveshaft instead of a car type slip yoke.
