What will work
Well there Dusterkid, it looks like your car could've come with either a 19" or 22" radiator in 73, so the first thing I would do is measure the opening and then determine what radiator you need by the size of the opening. A 225 shouldn't need more than a 22" rad, and this would be a good size. The part number for a 1973 Duster with a 22" radiator and slant 6 would be 3673005, and a 19" radiator is part number 3673004. Is this the info you need??? Geof
If you're good with minor mods, you can bolt in anything that has the hose connections on the correct sides that will fit between the framerails. Caint beat a good crossflow.
thanks that helps
