What's that stuff called.....
Small Block
West Plains, Mo.
......that ya paint around the ports on heads for marking out the guide lines. I've used it when porting for marking my limits but i cant for the life of me think of the name. Tune me up if you know. It's blue. Thanks guys
Small Block
We use a spray called Dykem Blue Layout Spray.Jayson
Jayson: You've got it. I've used the stuff you brush on with a small brush. I guess the spray would be fine. I need some so i'll be searching locally first. Thanks guys
Small Block
I prefer black marker, cheap, easy, and can be reapplied as fast as need be without using a brush.
Marking Dye. We use blue on fan/turbine blades that are blended on jet engines. I think Dykem is the brand.
Yep SB, I use Dykem Layout Dye Spray...I always use BLUE...its good for Intake Port Match porting, and a whole bunch of other port work.
I have a couple of blue magic markers I have been using for lapping valves and porting intakes, works well and is easy to find at thrift or art stores.
Interesting...May try the blue markers and see if i like em. Working on a set of 400 heads. I'm just playing in the shop. I think i'm going to have to fire up the air conditioner. Thanks guys
Small Block
