pauls340
I (we) could use some help setting up the shifter and trans. When I look at the pic I see the 1-2 ,3-4 trans levers facing the shifter and the reverse facing the fan. The shifter is the set in neutral, using a nail, that then determines the linkage lengths...correct? Thanks
