Whats your Big Block Combo?
400 block stroked to 451 (block filled to freeze plug)
-1 heads t&d rockers 1.6
cam motion cam 713 lift after lash
eagle h beams with arp bolts and je piston (14.1 comp)
eagle crank 4340
rbre main caps
kb ext. oil pump
440-2 intake with 2" spacer for 4500 carb
milodon gear drive
carb is not known as of yet
trans will be 727 rev patt.
8" verta 5600 or 9.5 5000
hope to make 700/750:thumblef::shaking:
400 block stroked to 470"
Eagle crank
Manley 6.760 rods
Diamond Pistons at 10.2:1
Eddy heads
Comp street solid roller 242/248@.050 .570/.576 lift
Smith Bros. pushrods
Comp Pro Magnum rockers
Eddy Perf RPM intake Holley 800 DP
Made 425 RWHP and a tick over 500 ft. lbs at 5500rpm:burnout:
440 stroked to 512 40 over, Edelbrock 88 cc heads with mild porting , 636 lunati solid roller, Harland Sharp rockers. Smith Brother push rods, 11.0 compression, super victor intake, 1100 pro systems carb. 440 source crank, Manley rods, icon pistons. TTi headers, 5800 Turbo Action stall, 430 gears. 3380 lbs. with 200lb. driver, best time 10.19 at 130 mph.
440 .030". Indy EZ-1 heads, Indy tunnel ram, (2) 750 Holley dp hp carbs, 10.0 compression, 1.6 Harland Sharp roller rockers, .613" .626" Hughes solid cam, 2" Hooker fenderwell headers. Was still pulling hard at 6000rpm on the dyno but didn't go any higher. 581hp at 6000 and 545lb/ft at 4900.
kb block, fully ported 440-1's, flat tops, aluminum rods, +.060"x 4.250, custom roller cam, mallory IV, donovan gear drive, kb extrenal oil pump, 14qt pan, 14-71@35%, hat and port injection, 9 1/2" convertor, 727(no brake), 4/10 dana, ladder bars, coil-over in all corners, 12pt cage in a 71 demon@3500lbs. :wack:
