Wheel adaptors
Mikes270dart
Toronto
Is anyone running wheel adaptors to run BBP rims on SBP hubs and axles. how do you like them.
I used them on all 4 corners for over a year without a problem.
The key is make sure they mount flat against the hub/drum.
If a weight on a brake drum interfears you will need to grind away a portion of that weight.
I used a pair for about 10 years on the rear of my cuda. Even did a bunch of street racing with big slicks and I never had a problem either. I had the big thick aluminum adaptors (about 2") just didn't like the offset it gave my wheels. Just dont use the cheep ones
