Since I put my Wilwood brake kit on, I haven't been able to move my car. Why, you ask? Well, I tried to put the stock 14" rim back on, but the wheel center was too small. Okay, so I got the old stock Jeep wheels out, put a rim (minus tire) on it, and it seemed okay. Got two new tires put on it, and went to put them on. After getting the right size lugnuts, I finally had them on.
I go to spin a tire to make sure they spin freely, and they don't even move. I found out that they hit the upper control arm ball-joint housing (thankfully not the ball joint itself).
So I say okay, I'll just find a rim that will have more backspacing, that'll work. Well, I measured clearance this morning, and I don't have more than 3/4" at the top of the wheel well. And that's with the wheel straight.
I am not sure what to do at this point, I want to try to not waste my 15" wheels up front, but I don't know how I can manage 15" wheels with that little clearance. Any ideas? I was just going to order some cheap 15x6" steelies on Summit with 4.75" backspacing, does that sound like it would work?
I am going to be changing wheels in the future all the way around, I just don't have enough money to do it right now, unfortunately.
