wheel wobble feel due to drum hub..?
Mrkidd
ok...i had replaced my old hub when the studs broke..the new hub slides into place without any effort....and the studs have a slight wobble to them......they arent pressed all the way in it seems so i took a hammer and hit them and nothing ...errrrr....i changed the bearings out and i beliveve my new drum has a slight warp but nothing major....is there anything i should look for to stop my wheel wobble fell...?
I have seen some older drums riveted onto the hub.. worked fine with stock steel wheels (had a recess in the back of them) but on my aluminum slots without the recess machined in the back, the wheel would not sit flat against it. I ground the heads off the rivets and fixed it. As was suggested above, post some pics....
