I hope this helps, it does have the big crank register!
DODGE & CHRYSLER ENGINES
MAKE AND YEAR C.I.D. LITRE BORE CYL. DESCRIPTION BLOCK CASTING NUMBER HEAD CASTING NUMBER CRANK CASTING NUMBER
1989-91 122
2.0
3.346
L-4 OHC, M.F.I.,
Dual Balance Shafts Shafts
1985-88 122
2.0
3.346
L-4 OHC, 2 Bolt Carburetor G-63
1990-92 122
2.0
3.346
L-4 DOHC, TURBO <
1981-82 135
2.2
3.445
L-4 OHC 5203630 5203655 5214738
1983-84 135
2.2
3.445
L-4 OHC 4105730 4105445 5214738
1985 135
2.2
3.445
L-4 OHC, Fuel Inj.,
11mm Head Bolts,
6 Hole Crank Flange 4343930 4323287 5214738
1985 135
2.2
3.445
L-4 OHC, 10mm Head Bolts,
6 Hole Crank Flange 4298430 4323287 5214738
1986-87 135
2.2
3.445
L-4 OHC, Carbureted,
8 Hole Crank Flange 4343830 4105782 5214990
1986-88 135
2.2
3.445
L-4 OHC, 8 Hole Crank Flange 4343834 4343830 4343930 4105782 5214990
1989-92 135
2.2
3.445
L-4 OHC, Roller Rockers 4315730 4501851 4105445 5214738
1984 135
2.2
3.445
L-4 OHC, TURBO,
6 Hole Crank Flange 4273330 4105730 4105445 5214738
1985 135
2.2
3.445
L-4 OHC, TURBO,
10mm Head Bolts,
1985 135
2.2
3.445
L-4 OHC, TURBO,
11mm Head Bolts,
6 Hole Crank Flange 4343930 4343530 4323287 5214738
1986-88 135
2.2
3.445
L-4 OHC, TURBO,
8 Hole Crank Flange 4343930 4343834 4343830 4387230 4105782 5214990
1986-88 153
2.5
3.445
L-4 OHC 4373230 4105782 4273232
1989-90 153
2.5
3.445
L-4 OHC, Fuel Injected,
Roller Rockers 4315730 4105782 4448486
1989-90 153
2.5
3.445
L-4 OHC, TURBO,
Roller Rockers, W/Steam Holes on Head Surface 4315730 4105782 4448486
1981-82 156
2.6
3.586
L-4 OHC, FWD,
2 Vent Tubes
on Side of Block G54 G54
1981-85 156
2.6
3.586
L-4 OHC, FWD,
1 Vent Tube on
1985-89 156
2.6
3.586
L-4 OHC, FWD,
W/O Vent Tubes on Side of Block G54 G54
1978-80 156
2.6
3.586
L-4 OHC, RWD,
Bell Hsg Dowel
Pins are 12 1/2" Between Centers G54 G54
1981-88 156
2.6
3.586
L-4 OHC, RWD,
Bell Hsg Dowel
Pins are 13 1/2" Between Centers G54 G54
1988-90 156
2.6
3.586
L-4 OHC, FWD,
TURBO CUSTOM R & R ONLY G54 G54
1987-89 181
3.0
3.29
V-6 OHC, FWD, Main Caps All One Assembly, Left Side Dip 6G-72 T3A
1990-91 181
3.0
3.29
All One Assembly,
Roller Camshaft 6G-72 T3
1990-93 181
3.0
3.29
All One Assembly 6G-72 T3
1990-92 202
3.3
3.660
V-6 OHV, Roller Tappets,
Aluminum Head 4448030 4448015 3654
1993 202
3.3
3.660
Aluminum Head 4621763 3654
1960-67 225
3.7
3.40
L-6 Crank Centering Ring
1.962" 2205528 2202857 2463430 2128654 2202952 2206035 2128492 2264479 2268613
1967-74 225
3.7
3.40
2.157"
2463430
2806830
2205528
2202857 2843169 2128654 2202952 2206035 2658998 3843935 3769307
1975-80 225
3.7
3.40
2.157", Mech. Lifters 2806830 2463430 4027600-5 3698447-1 4104362 3698966 7501366 2658998 2843935 3769307
1981-87 225
3.7
3.40
L-6 Cast Crank,
HydraulicTappets,
Crank Center Ring 2.157" 330 530 4095778 4095246
1990-91 231
3.8
3.780
V-6 OHV, E.F.I., Imperial,
Fifth Avenue, Aluminum Head 4448015 3654
1992 231
3.8
3.780
V-6 OHV, S.E.F.I.,
Imperial, Fifth Avenue,
Aluminum Head 3654
1986-87 238
3.9
3.91
V-6 Flat Tappets 4323730 4227979 4323769
1988-89 238
3.9
3.91
V-6 Roller Tappets 4323730 4227979 42323769
1990 238
3.9
3.91
V-6 OHV, Roller Tappets 4448019 4323769
1991 238
3.9
3.91
V-6 OHV, Roller Tappets 4323729 53005709 4323769
1992 238
3.9
3.91
V-6 OHV 4323769
1993 238
3.9
3.91
V-6 OHV, Roller Tappets 53006711 53006680 4323769
1962-66 318
5.2
3.91
V-8 Spec. Solid or Hydraulic
Tappets, Spec. W/Centering Ring
or Flat-Back Crankshaft
1967-75 318
5.2
3.91
V-8 . 2806030 2536030 2566080 2466090 2843675 2658920 2843868 2128869
1976-84 318
5.2
3.91
V-8 Bell Housing Brace Mount 9" From Rear 4104230 4006730 4179730 4027163 3769973 3671585 3751851 4027593 3462387 2658393 3751841
1980-84 318
5.2
3.91
V-8 Bell Housing Brace Mount 10" From Rear 4179730 4104230 3671587 4027596 3462387 2658393 3751841
1985-89 318
5.2
3.91
V-8 Flat Tappets 4323330 4323345 4323345 4343646 3751841 3462387
1985-89 318
5.2
3.91
V-8 Roller Tappets, Carbureted 4323330 4387560 4323302 4343646 3751841 3462387
1990-91 318
5.2
3.91
V-8 Roller Tappets 3751841 3462387 2658393
1992-94 318
5.2
3.91
V-8 S.F.I., Magnum
Roller Tappets, Custom R&R Only! 53009714 53006671 3751841
1968-72 340
5.6
4.04
V-8 Steel Crank 2780930 2531894 2532457 2843868 2128869
1972-73 340
5.6
4.04
V-8 Cast Crank 2780930 3671587 3418915 3658393 3462387 3751841
1971-89 360
5.9
4.00
V-8 3418496 3870230 4045601 4179930 4006830 4315830 3418915 4071051 4027596 3870084 3671587 4343475 4323345 4343805 3418640
1989-92 360
5.9
4.00
V-8 Roller Tappets 4315830 53006921 4323352 4343923 4343964 4448308 4027169 3418640
1969-71 383
6.3
4.25
V-8 Cast Crank 2468130 2843906 3482923
1968-71 383
6.3
4.25
V-8 Steel Crank 2468130 2843906 2206519
1973-78 400
6.6
4.34
V-8 Steel Crank 4006540 3698630 4006452 3751213 3769975 3462346 2206159
1973-79 400
6.6
4.34
V-8 Cast Crank 3698630 4006530 3769975 4006452 3462346 3751213 3751877 3462923 4027172
1968-78 440
7.2
4.32
V-8 Steel Crank 4006630 3830930 3698830 3769975 4006452 3462346 3751213 2206160
1973-79 440
7.2
4.32
V-8 Cast Crank 4006630 3830930 3698830 4006452 3751213 3769975 3462346 3751888 4027175 8698461
Back to MAIN Page
