Creedmoor
Recovering Fordaholic
68 Barracuda FB OK, heres what does NOT work: Both Front parking lights Front Right marker light Front Right signal Right signal indicator Hazards work fine and everything on the backend works like it should (except back-up lites but I think thats a separate issue). Ive done a complete and very anal connection cleaning of the bulbs, receptacles, ground connections at both ends, inside and outside of all connections. I have verified continuity all the way back to the bulkhead connector for all wires. I have voltage at the bulkhead for terminal Z which is parking and markers when I turn the switch to on. I have on /off voltage on terminal S when the ignition is on and the left turn signal is on. But when the right hand turn signal is switched on I have a steady 12V at terminal V. Could a bad flasher do all this? Did 68 Cudas have two separate flashers for hazards and signals? Help - What am I missing? Any and all advice really, really welcome! I friggin hate electrical! Mike
