Which Ignition Box Do I Need
Joseph24251_200
The Mopar Kid
Fayetteville
Ok I blew a head gasket a few weeks ago on basicaly a new engine. I'm thinking it was due to the ignition. I'm thinkin the ignition may not be up to the job of the engine, timing was set properly but at high rev's it sounds and feels like the timeing is off. I tried readjusting the timeing but i just couldn't get it to run properly at high rev's. At real high rev's i get a sound like marvels being thrown around in the engine, I asume this is light spark knock. So i know the timeing is off but could it be due to my orange ignition box also the car runs bad at times and good some other times. If i starte it up and and gas it a few times it's fine but after running it for a while sometime it would have a stumble when i press the gas then some time's its just fine all the time. My old all stock 318 would also stumble and run like trash some times and then other times it would be just fine. I'm starting to think my orange box may just be bad, or not enough for the engine. Should i go with the chrome box which is good up to 8000 rpm. Engine rev's up to 6000 pretty easy when it is running smooth, but when it starts stumbling it's hard to get it up to 3500 rpm. Engine spec's are at the bottom
Block: 360 .40 over
Pistons: Keith Black flat top 9.8-1 compression
Cam: Comp cam Nostalgia Plus .484 Int .484 Exh 20-672-4
Heads: J heads 2.02 & 1.60 valve milled to 68 cc
Ignition: Proform elect. Ignition with hp curve and Flame thrower coil 1.5 ohm Orange box.
Should I try an chrome box??????
sounds like a distributor problem? you describe the marbles sound. that's pinging(spark knock). BAD SOUND. you're total timing is too much. you need to tighten the advance curve down to somewhere in the 21* range. my old mp distributor had 29* of mechanical advance. it was horrible. consider you want around 34-35* total timing - 29*, well thats only 5-6* inital. horrible. you need to weld something in the plate area to lessen the amount of centrifugal advance.
So basically i need to weld up the weights in the distributor and if this is what you mean can u give me a lil more info on how to do this cause i'm about to take apart one of my electro distributors now and see if i can get it right
So redfastback if i where to put in stronger springs to delay the curve and put a light spot weld in the slots the weights slid in to stop them for sliding all the way back would this fix my problem. Or do u mean I need to weld something on the vaccum advance.
i am talking only about mechanical(centrifugal) advance. yes you weld it so it doesn't have full motion anymore. where? thats the fun part. its a precise weld. how much advance does it have to start with? this way you can know how much to limit its action. hopefully someone here has the pic or 1 lying around.
