Which Pushrods with Eddy Heads
jefflock
69 Dart 408 10.08 best pass so far
Kansas
Those who had experience in installing eddy heads on a 340, Which lenghth of pushrods did you use? I have an hydraulic cam and want to install Comp cams roller rockers. I tried using the ones that came with 273 adjustable rockers and they appeared to be to short. My adjusters ran out of adjustment before the lifters were adjusted.
the 273 pushrods were for a solid cam. You'll have to get some that are made for adjustable rockers and hydraulic lifters.
I'm running the 273 adjustable arms and pushrods on the eddy heads now.
