which shroud do i need
Mopar44134
Ohio
The radiator in my 68 is 22" inches wide. Mounting holes for the shroud is 22 X 13.5. I think the radiator came out of a 72 dart 6 cylinder.
Thanks
Part numbers from your radiator might help.
Original 22 inch radiator in a 68 would have the top to bottom bolt hole spacing closer to 13.25 between centers. That shoud for a V8 has part number ending with 614.
here is a pic of the radiator in the car. will the 614 fit this radiator. 68 radiators had the round tank. Does it matter? or do i need the 325 shroud? I didnt see any numbers on the radiator.
you will need the 325 shroud the 614 will not fit
