which transmission cooler lines do i need?
diymirage
HP@idle > hondaHP@redline
michigan
hey guys
im getting parts together to swap a 360/727 into my 71 s6/904 duster and im wondering which transmission cooler lines I need ?
the right stuff has 2 sets listed, the 6901 http://www.getdiscbrakes.com/ytc6901
and the 7001 http://www.getdiscbrakes.com/ytc7001 (which has a loop near the radiator)
I asked them the question but they couldn't tell me what the loop was for and if I need the ones with or without it
anybody have any experience?
here is an EXTERANL filter, i found. have one on my 01 dak. my idea is when you put a new filter in side this one will help from having to do the inside one as often.*
the old auto zone 2210 magenfine filter is no longer available at auto zone. BUT i did find the same thing as JX-160 brand-- ATP. at a real parts house uses 3/8" tube. a JX-150 for 5/16 tube. And NAPA 18721. ONLY use high pressure hose. If you must. SAE J1019 217 psi working. NOT fuel hose for a carb engine.
thanks guys
if no one else has any insight ill order the one with the loop tomorrow
