bad440
everything,all the time..
has anybody used the hughes 318 whiplash cam in a 318?it says they are for stock engines but they have a pretty big lift, says nothing about a loose converter either way.but it does say its for 8.5- 8.9 comp.
i was just sayin ,it has some lift.i guess my **** runs together lolThe whiplash cam series is made for low compression motors. Correct me if I'm wrong, but lift has nothing to do with how the converter will act, that is determined by the duration and the lobe separation in most cases.
