Who makes a GOOD spot weld drill bit?
Covington, Georgia
I need the bit to drill out the spot welds on my floor pans.
I would like to know if anyone has a prefernce or has used one that worked well.
I have looked at Eastwood and that may be what I end up with. So any thoughts, suggestions, or better ways to get these pans out?
I picked mine up at Harbor Freight for 4.99.....bought 2 firguring they were cheap, broke a tooth the first time I tried it, then got the feel of it and it works great, even with a missing tooth. The head is reversible so you get two cutters with each one. I'll be working in the area of Harbor Freight on Thursday and then again next week, if you'd like I can pick one up for you.
Dave
i must be left in the dark i just use a large drill bit. you know as soon as you get through the weld.
The cheap ones work pretty good .. I drill a small pilot hole to keep the bit from " walking " This helps a lot...
