JDMopar
3M or Fusor panel bond is pretty expensive stuff to use for seam sealer. I'd put that hump in just like you do when you convert an automatic Mopar to a 4 speed. Trace around it with a Sharpie, then remove it and trace another line an inch or so inside the outer one and cut it on that line. Then you will have plenty of a ledge to weld to. I have always used 3M Fast n Firm seam sealer and never had a problem.
If that bondo is pretty thick on the back of the cab, it should turn loose if you heat it with a propane torch. You should be able to scrape it right out with a putty knife and not have to deal with so much dust from grinding.
