Who sells a904 gear shift control levers?
keenkeener
Active Member
I have been struggling trying to connect a factory console shifter. I removed a B&M ratchet shifter and only now I realized that I need the the factory a904 gear shift control lever and not the shorter one that is on my tranny. I cant seem to find it anywhere online.
Am I going to have to hit up a junk yard?
You may want to get you a Yearone catalog. I think I saw one in it! When I get a chance, I will hunt mine down and look.
Come to think of it. there is no difference on stock levers. the one on yours may be the lever that come with the shifter. Matter of fact the 727 and 904 use the same valvebody so I can't understand why you can't use one from a 727.
Cuudak is right the 727 and 904 use the same valve bodies and levers. But the B&M one is unique for a B&M shifter.
I have some extra stock ones. Pm me if you want one and you can have it for the shipping cost.
