Who's using wire looms or separators
'74 Sport
Troy, TX
I would like to see what is being used to separate and route the spark plug wires on some of your small blocks. I need to get the maze of ignition wires under control on a 360.
Sources and pricing would be appreciated, too.
Jerry
I use wire ties usuall. One around the group of wires and one in between each wire to keep them from touching.
This is what I use. Good price and very high quality stuff. If you're not using a stock valve cover, you may have to make some mods. I'm using tall moroso covers and had to make some longer spacers and get some longer screws. Your wires may have to be custom made too, but the end result is well worth it.
http://www.summitracing.com/parts/RNM-1103R/?image=large
I am particularly interested in separators that run the wires parallel along the valve covers vertically, rather than horizontally, similar to these:
I use zip ties. One around the wire then one in between to seperate them with a piece of rubber hose on top for looks.
