Why are there different 727 and A833 slip yoke lengths???????
duster360
Alabama
I have been looking for a 29 spline 7260 yoke. I have noticed there are different length factory slip yokes. I have noticed that some of the length difference is where the splines start inside the yoke. Some splines start a little deeper than others or their is just extra material before the splines start. The yoke I have is 8" and others are 9" from center of yoke to slip end. Can someone shed some light on this?
That is a good question, I am not sure either. I do have a 7260 slip yoke off a 4 speed 73 charger if you need one.
there are 2 different output shafts as well. The 66 and OD trany use a 904 yoke where as the rest use a 727 size.
