[FOR TRADE] wide 8 3/4 trade for one that fits a Duster
Loggato
Central Kansas
I built this 8.75 for my duster because it's the only one I could find at the time. I was told it was from a late 70's Cordoba. It fits ok, but it's a little too wide for my liking. This will bolt right into any A-body with 43" spring perch spacing. I will measure total width and will update the ad.
I will need to keep my brakes and backing plates, I'm so/so on if I care to keep the center section (2.73). I have others.
I would like an 8 3/4 that is meant for an A body. I am located in central Kansas.
Let me know. thanks!
I have a housing that was cut and made 2 inches narrower than a stock A body. He put it in a d50 that the guy had too wide of wheels for. I also have the ends from Dr. Diff for it. I am in Jerseyville, Ill, close to St Louis, Mo, if you can't find 1. If you would like i will measure it and add the 5 inches for the Dr Diff ends and post them here.
I measured mine and it is 45.5 wide. Add the 5 inches of the housing ends to that and it makes it 50.50 inches. That would be 2 1/8 narrower, flange to flange. If that would work, send me a pm and we could work out a deal on something.
@Loggato
@Loggato
ok, let me measure mine and I'll catch up with you if it'll work.
