Will 14" 255/60 BS 4" fit on my Swinger?
They should fit,as I had 15x7 with 255/60/15,s on my 66 Dart.Just make sure you get the proper lug nuts with the rims.8)
The section width for a 255/60/15 tire is 10.2" on a 7" rim. I'll assume that the 14" equivalent will be the same since a 245/60/14 and a 245/60/15 have the same section width of 9.8 on a 7" rim. Checked on the BFG site. That said, I think it's gonna be a tight fit at the springs w/that wide of a tire. Isn't a shackle offset required to fit a 10" tire? May need to roll the wheel lip a bit too.
Here's a bump for ya anyway!!!
Yeah i think it will be a tight fit aswell :/ but with the right backspacing i think that 255's should fit in the rear, i was just curious if someone else ran the same combo on their swinger so i know for sure :)
