Will 22" fan shrouds interchange??
71autoxr
Phoenix, az
I have a later style radiator in my 69 Dart. Are the 22" shrouds interchangeable between radiators of the same size and engine (V8 vs ?6)? Yes Yes I know not to buy a repro P.O.S. one. Thanks
You'll need to go by the bolt hole spacing for the shroud on the radiator that you have.
Yeah, that is correct and also keep in mind if you put aftermarket pulley's,a/c unit etc...you open a whole nutter can of worms like I did and you'll be pullin out your frikin hair!
