Will Doors from '70-'74 Fit my '69 Dart
MadMaxCustoms
Olympia Washington
Hello
I have a '69 Dodge dart 2 door hardtop and need to replace both doors (the are rusted out the bottoms.
Anyone know if I can replace the doors with later dart models?
Will the doors from a 1970-1975 Dart be the same as the ones on my '69?
Hinges and all?
Thanks in advanced.
Max
Hello
Hinges and all?
Thanks in advanced.
Max
As for the doors..... I believe the 67-69 doors will fit, but I think the door push lock buttons are in a different location than the stock 69 doors location. The 70-74 doors will bolt up, but something is different but not sure what it is. The door hinges are the same for all those years. I hope this helps you some!
Any '68-'76 door from your same body style—square-body 2-door hardtop Dart or Valiant—will bolt right on. '73-up doors have side-impact guard beams built in, and no vent wing windows. '67 doors won't work because the door latch is different.
67-72 is a match but 73-6 will work too but they use different glass,door inards,no wings and different door panel set ups. The 69's moved the upper interior door lock button to the center of the door instead of at the back of the door.
